OT-where can I get ATX case w/8expansion slots.
Usually at least 1 PCI and ISA use the same slot. PCI cards go below the slot and ISA go above the slot so usually you cannot have all slots filled. Are you sure you can put 8 cards in at once?
Might be more of a cases & cooling question, but we can try and get it out of the way quickly.
As RD Mustang1 said, many (if not all) motherboards with both ISA and PCI slots share one. Check the site of the board manufacturer for specs.
