Originally posted by: PorBleemo
Originally posted by: MrFluffy
Originally posted by: IsOs
The most common caused of this type of lock up is heat. Check the fan of the cpus if the speed are still correct. The best way to tell if it's heat is by openning the case and pointing a fan into the system. If it doesn't lock up then you know it's heat.
The other caused of lock up is memory. If there's a chip that's about to go, having the system at 100% stress can caused the lock up.
Actually both of those I have tested, the most of which was heat (the funny thing is the more fans I put in the less it runs)...
It's either the MB, the PSU, or the processors (but most likely the PSU).
The even funnier thing is that my fans are spinning at over 600million RPM, and I also have a temp of 175degF on the MB, and both cpu's (but I can put my hand on each of the HS's without feeling much heat).
1. If you put in more fans and that causes the system to become more unstable I am lead to believe that your power supply might be dying. Can you post complete system specs please?
2. Take a can of compressed air and blow out the heatsinks for both processors and their fans.
-Por
As requested here are the complete system specs:
CPU(S): 1x MP 1800+ 1x Athlon @1533Mgz
RAM: 256MB Crucial PC2100@266
MB: TyanTiger MP (rev. 1.03)
Vid: ATI 8500LE
Sound: 1x Soundblaster Live!
HD: 1 Seagate Baraccuda (IDE) 1 WD (7200RPM) both are 20GB
Optic: 1 Toshiba 6x DVD ROM 1 TDK 12x10x32 CDRW
PSU: Enermax 330W (probably waaay under-powerd)
NIC: 2x 3com 3c90b
FAN: 2x 60mm case (1 for intake, 1 for exhost) 1x120mm (intake) 2x60mm CPU
OS: WinXP SP1
Currently I have the intake 60mm and the DVD ROM un-plugged, and I have tried taking off all optic drives and all fans (except the CPU fans), but it seems not
to matter. I was going to take off the WD HD (since it is going out anyway), but it seems like I can't load windows without it (forgot to set it to slave when I installed XP... oops). What I can try in the short-term anyway is to borrow on of Ray's AT PSU's to power the HD's, Optics, and case fans to alleviate some of the draw on the current PSU. unfortunately I cannot afford a new PSU
I'll try to tackle the re-seating of the HS/fans (it's a pain) sometime in the near future, but honestly it does not seem to be a heat issue.
-PS Ray, don't you have a spare 2000+ laying around
Oh yea, the PSU does have extensive heat exhosting.. . (which really indicates the PSU being the blame for the system lockups)
