Hi folks,
I have:-
Gigabyte GA-5AA mobo. (Latest Bios) (Sayds it supports UDMA-33 and ATA-66 in the manual)
Fujitsu 40Gb IDE disk (MPG3409 I think)(Brand new - must support ATA-66 at least).
I just went and bought an ATA-66 cable (80 wires instead of 40).
I test my disk performance first, swapped the old 40 pin cable for the new 80 pin cable, and re-tested the disk performance (with Virtual Dub).
It had dropped slightly. I have an old(ish) 24 speed cdrom and this IDE controller (secondary) too.
Any ideas how I check that ATA-66 is active/being used ?
I'm using this PC for video capture (and SETI/UD of course !!).
cheers,
Col
I have:-
cheers,
Col
