Hello all,
I have myself a little problem. I just got a new Netgear MR814 wireless router. I have all my wired comps in my room (3 of them) plugged into it and my laptop on the wireless. The way my house is set up the router for the internet is in the basement along with one other computer. Naturally I don't want to put my wireless in a hole in the ground, so it's up in my room. I figured I'd use the internet port on it just as an uplink going to the router in the basement. Well, it turns out that that won't work, it has to be a routed port. That's fine with me, because the only consequence is that the comp in the basement and comps upstairs can't see eachother in network neighborhood and such. Anyway, my problem is that my computer with the SETI Q server is upstairs. I figured I could just forward the port twice and have it work, but that's not been the case so far. My queue uses ports 5517~5519. I changed the forwarding of the basement router (Dlink) to the IP addy of my upstairs router. Then I set up the upstairs router to forward those same ports to my server machine. Problem is, it doesn't work! I'm pretty sure the problem has to be in my new wireless router since all was working fine when I just had the basement one. This is all I have done one the wireless one for forwarding:
# Service Name Start Port End Port Server IP Address
1 SETI Queue 5517 5519 192.168.0.3
I can ping the wireless router from computers on the downstairs router, but I can't ping the SETI Q server.
All help is apprecieted. If I lost you, say so and I'll try to fix it.
Thanks,
Swan
Thanks,
Swan
