OT: Help me out!
Migroo
Ive got a small problem I need help with here. Can anyone shed any light? Its to do with loading Windows 2000 server... it doesnt like the hardware..
Linkarama
migroo, try installing win2k w/o the nic. then add the nic after you've installed win2k?
change to a different pci slot?
Hi m2kewl 🙂
I should have mentioned that I've tried a difference PCI slot, but not with the Intel card. I'll try it.
Having talked to one of our guys here its not a good idea to install Server without a NIC installed... (confused..)
