- Feb 18, 2001
- 30,990
- 5
- 81
A few of you saw this case a while ago when I was working on my hard drive window. The case is finaly complete. I finished it last night. It is a k6/2 500 in a metalic briefcase, with external ports so you do not even need to open the case to use it.
inside
cooling fans
ports (power, Nic, 56k and monitor)
looks almost normal
4 fans fron outside
Stupid thing took forever, and I spent about $150 to build just the case. I made it to go under the pasenger seat in my truck and play movies and stuff when I get bored sitting in a parking lot or something. I even put an external modem hook up so I could connect to my cell phone and post here The sad thing is I measured incorrecctly, and the case is too tall by 3/4" of an inch to slide under the seat. To put it under there I would have to unbolt the seat, then put the case in, and then bolt the seat back down. That will not work, I want to be able to remove it. Oh well, back to the drawing board. I think I will have to buy some steel and make it myself since this is the smallest briefcase I could find.
Anyway, I need another wierd idea to occupy my time. A cool computer case would be the ticket. Something wierd that no one has done. Any Ideas?
inside
cooling fans
looks almost normal
4 fans fron outside
