Originally posted by: RagingBITCH
First, get it checked out to see what exactly the problem is. You might just be low on freon.
Originally posted by: Kelvrick
I know it'll be expensive for my car. I'm still on R12.
Figure out if you use 132 or 12.
Yeah, it should be 134a. Chain stores suck IMHO. Find a reputable independent mechanic. Or if it's just low on freon, you could do it yourself pretty easily.Originally posted by: LakerGod
Jesus...100 bucks is a lot. Since my car is a '96, i'm pretty sure i use the newer, less expensive freon.
Originally posted by: Rage187
"Or if it's just low on freon, you could do it yourself pretty easily."
You cant buy freon unless you are certified.
You can however buy R134A AFAIK.
You can buy entire transfer systems at Autozone.
We're using the term "freon" loosly here.Originally posted by: Rage187
Yeah, I meant 134a, not freon proper.Originally posted by: Rage187
