- Jun 7, 2002
- 2,820
- 0
- 0
*ack*. I'm having big problems here. Part of my job is to do substantial amounts of file transfers to artists over at newsday (local newspaper). After 2 years of using email with a lot of hassles, we finally convinced them to setup an FTP server to handle the transfers.
Ok, so on our end, we have a bunch of macs running osx (jaguar) which NEED to be used for preproduction stuff for the files. Basically, the main g4 acts as the processing plant and archiving area. My problem is that every osx ftp client I try (fetch, +some freeware stuff) to use is quirky and ends up dieing a couple files into the transfer. VERY annoying. I can't just reconenct either. actions get queued and I have to force quit and sometimes it's still messed up.
*sigh*. It's not the server. I can transfer zillions of directories and files on my pc to the same server, never a problem. It's got to be the mac.
I was hoping to just share the files over the lan and ftp stuff over on my pc, but I can't login as the main user over windows (yes, I did check the "allow windows login" box), and using seperate accounts, I can't create/manage directories (locally) in the secondary users' path without an incredible amount of labor.
-help-
(god I hate macs sometimes)
-help-
