I'm doin' the OSPF labs right now... And I have some confusion with DR and BDR elections. Iot says that the DR and BRD are determined by priority which has a default of 1. It then says, in the case of a tie, the router ID, which is the highest router ID... Which is an interface IP address.
Now, this is the way my routers are configured:
Vista - e0,192.168.100.246/28 lo0,192.168.31.22/32
SJ1 - e0,192.168.100.248/28 lo0,192.168.31.11/32
SJ2 - e0,192.168.100.247/28 lo0,192.168.31.33/32
OSPF is running... I assume, since I aint too clear on the notation... On the 192.168.100.240/28 network (network 192.168.100.240 0.0.0.15 area 0)
However when you look at the DR and BDR, it seems that the loopback addresses and not the e0 addresses are the router ID's. What gives? 192.168.100 is higher in number than 192.168.3x
