BonzaiDuck
Let me describe my home server.
It is an olden-times ASUS top-end 680i motherboard with three PCI-E x16 slots, of which two would only operate with 2x 8x in terms of bandwidth and lanes. The nForce controller is not AHCI compliant; the PCI-E slots are all version 1.0.
But it had been an RMA-repair or replacement board, which I put back in storage. That board was released around 2006, but when put in commission last year, had less than a year's accumulated usage.
So, toward disabling the nForce controller, I installed two $70 4-port, port-multiplier capable controllers limited to any single port of the four, with BIOS options for JBOD, RAID0, RAID1, RAID10, or "Not Configured" for AHCI with native MSAHCI driver. In addition, the Marvel controller included a "Hyper-Duo" feature parallel to Intel's ISRT SSD-caching, HDD acceleration feature.
But these cards have their maximum bandwidth at 250MB/s -- at the most. This, in fact, corresponds to readings taken with the StableBit Scanner program, with graphs of MB/s against time for each drive viewed separately at any given time.
The linked Anandtech article below focuses on AMD versus Intel technology of the year written, but the useful information for my purposes here is the discussion about PCI-E 1.0 versus PCI-E 2.0:
http://www.anandtech.com/show/2973/6gbps-sata-performance-amd-890gx-vs-intel-x58-p55/2
At the same time, I anticipate replacing the 680i board with an EVGA 780i "SLI" 3-way-capable second-tier board. The board provides PCI-E 2.0 in all the x16 slots.
To this end, especially since the same storage hardware, drives, virtual-drive software would simply move to the new motherboard and that the 780i would follow the plan to disable nForce, the only hardware and drivers that would effectively change is the chipset with its chipset and system drivers. The earlier 680i would likely be a subset of the 780i, so Windows Home Server 2011 would boot without problem, and I should only need to install the 780i chipset drivers if WHS did not provide a WHQL set on its own.
So I'm thinking to skip the SYSPREP and just about everything else except the chipset and perhaps the audio drivers (audio is disabled for the 680i). I would like to have the ability to revert to a cloned 680i-configured OS disk if something goes wrong.
So the most pressing of all these questions is this one. I've been happy that I can reinstall WHS 2011 on new hardware, and I think the most recent pairing with the 680i system is the second of such pairings with the OS.
I understand that OEM disks have a limit of three such activations. Or am I wrong? Is the limitation accurate only for branded OEM disks?
Should I worry about installing WHS on a third hardware configuration?
I want to keep consistent with the common principle: "Don't fix it if it ain't broke," while I take a chance on using newer hardware for better disk performance. This has to be reversible to the last pairing of OS and hardware if something goes wrong.
I'm not ready to shell out yet for Server 2012 R2 or "Essentials." In addition to the cost, I'm not ready to go through any reinstallations of OS and all the software unless absolutely necessary. CoveCube should guarantee free license activation for StableBit on the same OS's reinstallations -- they did it before. Even if not, that's ~$35. The only other add-ins are AAC or Advanced Andministrative Console, the stablebit scanner, Serviio -- which is free, and the NOD32 AV program.
So again: Should there be any problem for a fresh reinstall of WHS2011 on new hardware after two previous such installs? And does the fact that the 680i drivers manage a subset of 780i features likely mean I can get a clean transfer of boot disk and Event-Log bill-of-health by simply installing the 780i drivers or seeing WHS make the update automatically?
