- Jan 4, 2001
- 41,596
- 19
- 81
The car is a rebuilt '97 Hyundai Elantra GLS, bought in 2000, with an aftermarket security system.
Nothing on the security thing's casing indicates the company, only "Made in the USA" on the front, and wiring info on the back. There is a small shred of a sticker that once had the serial# printed on it. Only 3 characters are still there.
The best I've been able to trace down was the manufacturer, Delta Vehicle Security, based on this FCC ID#: J5523518R.
Google has only turned up this site..
Calling them only got the messaging system, and they don't look like they've invested much in their website.
The box is connected to something else, which has a 10-digit # silkscreened onto it, as well as some of what looks to be Chinese writing.
Are there any good places to go to get new transmitters?
I already have one, but my car is useless if it is somehow disabled. I had a scare today after replacing the ailing battery - it refused to relinquish control of the car to me. I contacted the garage where the car was rebuilt. His only suggestion there was to hold the button down for several seconds, which did do the trick. He didn't know who the manufacturer would have been though, so I had to do the FCCID thing.
So I'd still like to get a spare transmitter, but aren't they going to need a serial number of some sort? How does that work? Are there any good sites to check out?
HALPS ME O mighty knowers-of-cars!11!!!!
