- Jan 8, 2004
- 2,166
- 0
- 0
Ok i just ordered my 6800GT from eVGA.com...which has offical set me on a time clock to build this computer! Finally i shall have it lol...Anyway here we go with what i want and what i plan to get. Any opinions appreitated, i just need the final ok so i know i am not screwing myself over. I have 2g to spend and i am leaving for vacation on the 29th and wont get back till the 1st. The video card ships the 2nd so i want my computer parts here before or when the video card arrives! I will buy buying from new egg so i plan to buy tomorrow..does that make sense?
2000 budget system:
http://www.newegg.com/app/viewProductDesc.asp?description=19-103-463&catalog=23&manufactory=BROWSE
Amd64 3500+
http://www.newegg.com/app/viewProductDesc.asp?description=13-131-499&catalog=23&manufactory=BROWSE
ASUS "A8V Deluxe Wi-Fi" K8T800 Pro Chipset
http://www.newegg.com/app/viewProductDesc.asp?description=22-144-152&catalog=23&manufactory=BROWSE
WD 160GB 7200RPM OEM
http://www.newegg.com/app/viewProductDesc.asp?description=27-152-023&catalog=23&manufactory=BROWSE
NEC 8X Black Dual Layer DVD+/-RW Drive, Model ND-2510A BLK, OEM BULK
http://www.newegg.com/app/viewProductDesc.asp?description=26-104-151&catalog=23&manufactory=BROWSE
MX510
http://www.newegg.com/app/viewProductDesc.asp?description=29-102-171&catalog=23&manufactory=BROWSE
Audigy 2 ZS GAMER LE
http://www.newegg.com/app/ViewProductDesc.asp?description=11-144-026&depa=1
Already have Xdreamer-2
http://www.newegg.com/app/viewProductDesc.asp?description=37-102-143&catalog=23&manufactory=BROWSE
XP PRo
http://www.newegg.com/app/viewProductDesc.asp?description=20-145-450&catalog=23&manufactory=BROWSE
Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200 - Retail
I plan to buy a monitor but i dont knwo which one yet...
this one is a maybe http://www.newegg.com/app/ViewProdu...-001-119&depa=1
I already have a Klipsch 5.1 set up
What do you all think?
3500..the memory and all..
Thx a lot!
comes to about 1,600 so far
2000 budget system:
Amd64 3500+
MX510
XP PRo
Thx a lot!
