- Oct 26, 2000
- 16,018
- 5
- 0
Originally posted by: Roger
Moisture mixed with oil, this is normal for winter time driving, moisture is drawn in wioth the intake air, turned to steam in the combustion chamber and makes it's way past the piston rings ending up in your oil.
One good long highway drive will clear your crankcase of this.
Originally posted by: MichaelD
Roger is the man when it comes to anything w/an internal combustion engine.![]()
As an added piece of useless data, the orange color comes from the acids, chemicals, sealants that find their way into the oil from your engine and the gasoline.
The PCV valve (Positive Crankcase Ventilation) does this wonderful service for you, on a good long highway drive, the oil temps stabilize at their warmed up temperature, this causes the impurities to boil off, the PCV valve then sucks these impurities into the intake manifold to be burned once again.
(The PCV valve is directly connected to a vacuum source on the intake, the valve regulates the airflow)
Don't most older cars just vent into the air?
Older lawnmowers do, at least. Newer ones pipe the breather to the intake.
Older lawnmowers do, at least.Newer ones pipe the breather to the intake.
Interestingly enough, performance parts companies like Moroso make extraction systems that connect the crankcase to the exhaust system, and use the low pressure created by escaping exhaust to draw out crankase gasses to reduce pressure. This will work well on cars that have highly efficient exhaust systems with no backpressure.
