Originally posted by: TheStu
Usually you can get yourself an AC Adapter for your car. Plugs into the 12V Cigarette outlet, and has a 3prong AC plug on it. You plug in your laptop brick and you are good to go. Make sure you get one with enough wattage to power your laptop though. Easiest way to check would be to simply look at the power brick for your laptop. Depending on how new it is, and if it isnt a monster (17"+ screen) anything that outputs 75-100W should be sufficient.
Originally posted by: corkyg
Inverter is a good idea - that converts car DC to AC. But, a better long range sokution for the traveler is a combo power brick - I have one from HP that goes with my laptop - will connect to cirgarette lighter, airplane power outlets, etc., as well as normal A/C. That is what I travel with - I leave my regulart power brick at home.
Targus makes a unversal A/C, air. auto brick, and that works.
Adapter
