Option 1 vs Option 2, best Air vs unknown water setup
WoodButcher
2,158
neat tip marci,
Some where I saw a review of different rads, heat tranfer capacity or capability in watts.
I lost it. any one know where?
aigomorla
21,087
3,596
Marci, can i link your radiator review over at XS on my sticky in this forum?
It would be a great bit of info for people that want comparisons.
Or can you write it up here, and i can ask the mods if at all its possible to sticky it. Info like the radiator review your crew conducted as well as radicals owns tests are great sources of info.
Marci
16
Sure - go fer it...
Heh... righty... the world of quality radiator reviews... here it comes!
Methodology: http://www.thermal-management-...tor_test_procedure.htm
Equipment: http://www.thermal-management-...est_equipment_list.htm
ThermoChill HE Series - http://www.thermal-management-...g.com/Thermo-Chill.htm
ThermoChill PA Series - http://www.thermal-management-...ng.com/ThermoChill.htm
Coolingworks Radiators - http://www.thermal-management-...g.com/coolingworks.htm
HE vs BIP vs Corsair vs Swiftech vs.... - http://www.swiftnets.com/Techn...ator%20Performance.pdf
BlackIce GTS240 vs Coolrad Series - http://translate.google.com/tr...com/articles-38-0.html
Those are the best validated and accurate radiator reviews around, covering all major brands.
SparkyJJO
13,357
7
Originally posted by: aigomorla
Originally posted by: Marci
Where did you get this info from? Anyone know of a good site that shows heatoutput of common components at stock and when overclocked? An e6600 really runs at 131W when overclocked? almost doubles its heat output?! wow thats crazy
Common knowledge within w/cing scene - the maximum poss heat output of an item is equal to the maximum power consumption of an item. An E6600 at 3.6Ghz with 1.45v consumes 131w... so at full load will create 131w worth of heat at most. So to summarise the maximum possible heatload of a system, just use a power consumption calculator for each item that you're attaching a waterblock to.
EG: http://www.extreme.outervision.../psucalculatorlite.jsp
omg marci is that calculator correct???
Recommended PSU Wattage: 1517W!?!?!?!? @ 100% peak?
What did you put in there, 20% cap aging and 20% surge comp and multiple PCIe cards? :p
OK but seriously, what were your settings in there?
4 raptors.
Q6600 @ 3.6 @ 1.50V
2 7900GTX <--- there overvolted to those specs
2 ram.
11 fans
1 fan controler
1 relay.
2 opticals
3 usb
Total comes out to 1517W
I put the same in and got 680W. I have no idea how you got more than twice that :confused: Even when I put in 50% cap aging I still only got 1020W.
VinDSL
4,869
www.lenon.com
Originally posted by: JEDIYoda
marci 7 posts.....no real history on thse forums...
Gotta prove yourself....
You might be right but understand...sometimes post count does influence whether you trust some people.....
Pics and screenies will put you on a fast track too... ;)
aigomorla
21,087
3,596
guys, he doesnt need to prove himself.
Thats the Marci i mention thoughout my posts when i try to back up data thats relavant to watercooling.
He's also a legend over at XS forums. Not to mention owner of thermochill Radiator companys.
Sparky and I can vouch for his credibility.
I will almost take his comments as given fact unless he says something completely outragous. The other people who i can vouch for with little to no post record would be nol, aka noob of leet. There isnt a better person to consult if phase change is in your ball park.
As for marci, he knows his watercooling on a level higher then most people care to take it. And there are a very few people i would hold in his ranking on this knowledge.
VinDSL
4,869
www.lenon.com
Thats the Marci i mention thoughout my posts when i try to back up data thats relevant to water cooling.
He's also a legend over at XS forums. Not to mention owner of Thermochill Radiator company...
Okay, fine! That's good enough for me...
Your word is golden, IMHO!
All hail, Marci! :D
Welcome aboard...
aigomorla
21,087
3,596
actually i stand corrected again.
He's the technical manager, and PR for thermochill.
He's still a high ranked staff for thermochill, and its a great addon.
Anytime any vendor decides to make an account over at this forum is a definite win for the overall community.
