Need advice in optimising my new system.
My new System:
T-Bird 1.2 Ghz (9.5 Multiplier, 133 FSB),FHS - GlobalWin FOP 38 (noisy mutha).
Asus A7V-133 m/B - Bios - Rev.1001c., VIA 4in1 divers v.4.24(2).
Hyundai 256 Mb PC-133 (Cas 3). Auto settings in bios.
IBM HDD 45 Gb ATA-100 7200 rpm - Promise ATA 100 Controller - latest drivers).
Quantum Fireball 13.5 Gb HDD (Standard IDE).
Pioneer 8x DVD 32x CDRom.
Matsushita 4x Wr 8x R - CDR.
Iomega 100Mb internal ATAPI Zip drive.
Asus 6800 Deluxe AGP Graphics card - 32Mb DDR. Detnator 3-ver 6.5a Drivers
S/B Live Sound. Latest Drivers.
Garnet 2100 PCI Satelite Card. Latest drivers.
Intel Pro-100+ PCI network adapter.
Lian Li aluminium case - 3 case fans.
Dual boot Win2K & Win98se.
DirectX 8.0a
I've spent two days searching forums and downloading latest drivers.
Problem: When I run 3D Mark2000 Benchmark (1024 x 768 -16bit), my highest score under Win98 is only "5800". And under Win2K is only "4700". Most tests in same spec. systems get an average of over "6500". My mates, 700 Duron - A7V - 128 Mb sys. scores "5500".
Also acccording to Asus Probe utility - CPU temp at idle is 57 degC (134 F) and M/b temp is 34 degC (93 F). Seems too high!!
There is no noticable difference if I run the standard Multiplier setting of 12.0 by 100 FSB to 9.0 by 133 FSB.
Would Appreciate any advice!!
My new System:
DirectX 8.0a
- Will playing with the RAM settings in Bios Help?
Will upgrading the Bios help optimise my system?
Are there any other drivers I need to load other than the ones mentioned above?
