Magnus Blade
Hey there.
So, I plan on re-using my optical drive from my pre-built eMachines EL1360G desktop in my upcoming custom build, as advised in another topic I made a few weeks ago (I didn't want to necropost there, so I made a new thread). I do have one little concern, as I figured I'd try to get it addressed before my parts get here.
My question is: Do optical/DVD Drives automatically install themselves into the system once you've connected them into their respective ports with the power supply? Since I'm re-using it from a pre-built machine, I don't have any disc software to install it's drivers/etc. if it has any. It's about my only true concern while thinking about building this new machine, and since I was told I can re-use the drive, I assume it'll begin functioning immediately after it's hooked up and connected, but I just wanted to double check here.
