Optical cables hard to plug in?
cpals
4,494
So I'm setting everything up now and for the life of me I cannot get the optical cable to plug into the TV. It looks like it should fit, but it doesn't snap in or anything. I push pretty hard and it still won't stay and I don't feel any kind of 'click'.
I'm lining the ridges up and everything, but maybe I'm missing something. I didn't think it would be that hard.
cpals
4,494
Disregard... I'm an idiot. :)
Upon further inspection, it was discovered they have little plastic caps on the front of the cable to protect the end. Heh.
MustISO
12
There's no cap on the end of the wire is there? It should go right in with little effort.
Edit: beat me by a minute!
spidey07
65,469
hehe, another falls to the dustcaps. Easy mistake.
Also, the connector should have a firm click when it is properly seated.
Tiamat
14,068
I read your OP and I know exactly this was the problem. :D
FP
4,568
I have a problem getting them off of my receiver. The damn things won't pull out. They pop out without incident on every other device.
/shrugs
Glad you figured it out Op
Sep 12, 2004
16,852
59
86
/shrugs
On some devices they aren't really caps but are spring-loaded flaps instead. They fold out of the way as you push the TOS connector into the port.
cpals
4,494
/shrugs
The problem wasn't on any of the devices, but on the actual optical cables. The cables themselves had little plastic bulbs on the ends of them to protect the optical ends.
Greg Goode
Thanks for this thread! I would never have noticed those little caps. The cable kept falling out. I was like wtf....
rms5366
so I been trying for over a year to get this cable to fit into the port on the back of my tv and you're telling me all I had to do was take the little bubble part on the tip off? Man, I knew I was stupid, but I didn't think I was that stupid :tearsofjoy:
Oh geezLes
My optical audio cable wont go in and I have caps off. there really is a problem with these things.i have a real problem I’d like to address. I want an answer to mine. I’ll bet nobody has it. No joking here. I wish my problem was like yours.
Muadib
18,093
899
It only goes in one way. Are you sure that you are lining it up right?
Oh geezLes
Seriously. I wish problems with that cable were that easy,
wtf. My caps are off . Still don’t fit.
yes it’s only so easy and obvious . I see exactly the bigger flat side smaller square part. Are there 2 or 3 diffeent sizes of these things ? My mistake if I didn’t know that. Just won’t go in and snap and stay in. Don’t get it . Staying with rca cable I guess.
