I have 2 Amd Opterons running windows 2003 and SQL 2000 with 8GB of RAM When I use 4GB I have no problems, as soon as I use switch /PAE and use all 8GB SQL crash with error "SQL2k: Process 54 generated fatal exception c0000005" Any Idias?
Why do you need 8 GB of RAM for a SQL database server? If your database needs that kind of horsepower, you should really be looking at a UNIX/Oracle solution.
Actually, from experience I would say a single PC running SQL server is more powerful than 5 boxes with the same hardware working together in an Oracle RAC system.
MS actually did something right. (In stealing the code from Sybase heh).
