I?m having some temperature problems with my CPU.
I have Opteron 170 with Venus 12 HSF. The rest of the system is as follows:
Opteron 170 X2 Core
HSF Venus 12
Asus A8N32-SLI
2Gb Patriot ram
Raptor 74GB
Case Wavemaster
The temperatures I?m running:
Idle 45C
Load under Prime95 torture test after 30 minutes 56 and rising.
This system is not overclocked. I have tried twice applying Thermal Compound that came with HSF, after cleaning of course, and I get same results. I?ve also bought cleaning solutions by Arctic, and their Artic Ceramic compound. Cleaned the CPU and HS very well, many times. Applied Artic Cemamic as per instructions (3rd time I?m applying it, so I should be good at it). Well, and I still get similar temperatures.
Any advice? Anyone running Venus 12 on Opteron? What are your results
Thanks
Opteron 170 X2 Core
HSF Venus 12
Asus A8N32-SLI
2Gb Patriot ram
Raptor 74GB
Case Wavemaster
Idle 45C
Thanks
