I just got a opteron 170 (CCBWE 0550UPMW) and I think it's running kinda hot, 37C-38C idle which is fine but a little warm IMO, but when it loads 100% it goes up to 52C-53C, that's everything in stock. I currently have it priming at 2.4 with stock volts, getting same temps.
I had a 3000+ venice at 2.6 with 1.47v in the same system getting temps of 35C idle and 42C load
My goal with this opty is 2.6 and above but looking at the temps I'm afraid to up the volts, so what do you guys think?
If needed, my system:
Opteron 170 with Thermalright SI-120 HS
MSI K8N Neo4 Platinum - bios 1.B(latest I believe)
Corsair 2x512 3200XL
Antec TruePower II 550
I use MSI's CoreCenter program for temp readings
