Have managed to get my opteron from stock 1.8ghz up to 2.85 ghz, but seem to have hit a brick wall - the voltage is the highest the board will let me go (1.55 V) and the temps I'm getting are comfortably under 30 degrees C. My RAM is also running under stock speed and the LDT is at a x3 mutli with the FSB at 317.
I'm assuming that its only the CPU causing problems? Windows wont boot with the FSB any higher, although the CPU is fully stable at 316-317FSB
I'm not sure of the stepping, forgot to check when I installed my water cooling -
Any ideas as to how I might be able to push the CPU up a bit more? I'm aiming for 3.0Ghz if possible
Any help would be much appreciated!
