Opions on fan controllers....
frldyz
Almost finished with buying all the components for my 1st build.
This is what I have:
i7 4790k
gigabyte z97x gaming 3 - mobo
noctua nd-h14
Samsung 850pro SSD (512gb)
corsair ax 750 psu ( 80 gold )
crucial ballistix sport 16gb RAM (2x8gb)
corsair 760t case
lg internal Blu-ray burner
internal flash card reader ( yes I still use flash cards... feel free to laugh )
What I intend to buy:
2 4tb HDD in Raid 1
GPU - have no clue on GPU yet. Still educating myself. But I will run 3 monitors.
Thinking of buying some HDD coolers or fans.
Possibly some LED light strips..
Possible extra fans to blow from top of corsair case in or out
Now heres my ?. I have 1 extra slot left on my case. I am thinking of adding a fan controller. Is it needed? Probally not. But I want to mod my set-up and case as much as possible.
Tell me If I got this correct. A fan controller will only adjust the RPM of fans that have PWN? A fan that does not have PWM just runs @ the RPM it is? Would it be possible to mount the fan controller somewhere on my desk. Possibly underneath a shelf that my monitor is under? My case will be mounted high on a shelf. So viewing the fan controller would be a PITS.
These are what Im looking @
NZXT Sentry-2 5.25" Touch Screen Fan Controller - Newegg.com
AeroCool Touch 2000 Controller, Panel - Newegg.com
KINGWIN FPX-002 Performance LCD Fan Controller Black - Newegg.com
NZXT AC-SEN-3-B1 Sentry 3 5.4'' Touch Screen Fan Controller - Newegg.com
I just think it would be cool to mount this right in front of my above my monitors. Run the wires to the back and into the back of the case.
