Question Opinions on the Phanteks Enthoo Pro case.
Terabyte 11
19
I'm working on a new build and I'm working on figuring out what case to use, I'm liking the Phanteks Enthoo Pro as it looks like a good quality case with lots of room at a decent price. I'm just wondering if anybody here has used it and could give me some general info on the quality of the case, and if there's any issues with it I should be aware of before buying it. Also I know the internal structure is metal but I haven't been able to find out conclusively if the outside of the case itself is metal or plastic, so info on that would be great too.
Thanks for all the help.
35,862
17,403
I was thinking of an enthoo but decided my cat would claw the hell out of it.
I ended up getting a phanteks 600s which I really like. Front and top panel are magnetic so you can easily remove them if needed.
Per research removing them doesn’t help cool that much more but overall I really like this case. Hard drive mounts in the back, hinged door, easy cable routing.
DigDog
14,581
2,974
Gamers Nexus gave the P400A the best case of the year award, and they should be pretty much in the same ballpark both in price and in looks and functionality.
UsandThem
16,068
7,383
If I needed a new case for a build right now, that one would likely be at the top of my list. I first saw it when watching a HardwareCanucks' review on it.
It has a lot of similar features my Be Quiet case has, but costs less and doesn't have a front door. The airflow is really good even with the panel in place, and I love how a person can simply tilt it if more airflow is needed.
Terabyte 11
19
The 600 looks nice, but I'm looking for a Full Tower case which is why I was asking about the Enthoo Pro.
Why would your cat claw the case?
UsandThem
16,068
7,383
It's an older case (one that I considered many years ago), with many hands-on video reviews on hardware sites and YouTube. They should be able to give you all the info you need concerning if it's a good case or not for your requirements/needs.
Feb 4, 2009
35,862
17,403
It’s nearly the same size, within 1.5 inches
His Majesty (my cat) likes to claw at anything fiber or soft plastic. I know he’s go after the filter.
