Opinions on Cooling a A64.
BoomAM
4,546
Hi.
When i upgrade, when 939 hits retail, i was planning on going for a WC Cooling system for the CPU & NB. Specifically, an AseTek kit. Mounted in a Antec P160.
Im after;
Quietness.
Good Temps.(Sub 40*c)
Some OCing headroom.
Would i be better off going for silent componets, like a Zalman CPU HSF & Some dampening material, as well as a second 120mm fan for the case?
Or would i be better sticking to my original option of the WC setup?
Thanks in advance.
govtcheez75
2,932
you probably can't beat watercooling, but unless you're going to be doing some EXTREME overclocking....I think it's overkill. I would probably just go with a Thermalright, or Alpha Pal. They both yield very good temps.
