Opinions on 2009 Subaru Legacy GT
Mide
1,547
So I'm looking to upgrade my Honda Fit since it has been snowing more-so AND I am tired of taking the wife's Impreza to go out to the desert to go shooting.
Requirements:
AWD
Turbo
5AT or CVT
I know that there was a WRX auto but only 4AT so that's a no-go. The current year Legacy GT is only manual so that leaves me with this 09 GT that I found. $21K used with 11K miles. Does anyone have any experience with this car?
I had originally wanted a Nissan Juke but I went to the dealership to take a look. The trunk is way too small to justify the car & price.
T2urtle
3,432
^ yes why exactly are you after this turbo... plan to mod the car? because if you dont i would take a V6 over most turbo motors out there. But when it comes to modding to make power a turbo motor is just a bit easier.
audi A4/A3 have turbo, auto( 6 gear DSG) and AWD
acura RDX is you want to go mini SUV
GTaudiophile
29,767
33
I have no respect for the Toyota Legacy, especially since its precursor was such a gorgeous car.
Subaru went down hill after this:
Mide
1,547
Do you just want a turbo for the sake of a turbo, with no specific power requirement?
Yes it's just a personal preference but I'd rather have a turbo-charged 4-banger than a v6.
cheesehead
10,079
Because the wife can't drive stick
Then tell her to drive her own !#!$ car. :p
Also, consider investing in a set of proper snow tires. The difference between good rubber and bad rubber is actually bigger than the difference between FWD and AWD - especially with cornering and braking. A good set of snow rubber on steel rims is about $700 shipped from Tire Rack, and may mean you don't need a new car at all.
Thoughts on the Subaru lineup:
1. The Subaru WRX is pretty much the best practical sports car on the market. $25,000 for a 265HP turbo engine, practical hatchback, and AWD. You can even get STI-spec suspension for a few hundred more.
But forget about the automatics - they don't work so well with the turbo.
2. The Subaru Legacy is a very nice car. The very low off-boost power of the turbo engine (identical to that of the WRX) in the GT makes an automatic gearbox a bad idea. However, if you have the cash, the flat six is good.
3. Saab sold Subaru Imprezas as the "Saab 9-2 Aero" for a while. They're basically WRXes with automatic gearboxes and all the luxury options. If you're dead set on an autobox and don't want to pay for a Legacy with the flat six, this isn't a bad option.
4. Subaru's normally-aspirated engines are quite good. Remember, up until the turbo spools up at about 2500RPM, the non-turbo engine actually has more power. They're cheap, too - you can pick up a brand new Impreza hatchback with an automatic transmission for under $17k around here.
5. VW/Audi makes a variety of rather nice cars with their DSG automanual gearbox, notably the S3 and Golf R32. However, they're a bit spendy, and the upkeep isn't exactly cheap either.
6. The Toyota Avalon is massively underrated - it's basically a low-spec Lexus. It's also very cheap. While it's only FWD, the big V6 in the front means it's quite good in the snow. It also does an impressive 28mpg on the highway - as good or better than any of these cars.
7. If you can find one, buy a Jaguar X-Type. This may sound a bit odd, but the X-type was actually a luxury european Ford sold as a Jag. While initially overpriced, they depreciated like bricks - a good one with low miles and AWD is under $10k.
Jumpem
10,757
If you really want an AWD turbo four cylinder that can run as an automatic, get a Lancer Ralliart or Evolution with the TC-SST.
Rezist
726
Yeah don't buy a stick if the wife/gf can't drive stick it's just a pain in the ass.
That being said if your going off road in the desert would you not want a little clearance?
cheesehead
10,079
Those things are ah heck-all expensive. You can the new Volkswagen Golf R for less than the Ralliart.
Mide
1,547
Yeah clearance is good, but what choices are there? The forester comes in a turbo but with only a 4AT or the RDX too but I don't need all the lux of an Acura. Oh well I think I'll just go test out the GT and see if I like it.
cheesehead
10,079
The RDX is basically a tarted-up CRV. It's not very fast, and while the CRV is nice in the snow, the Subarus have a much more clever AWD system.
If you're dead set on a Subaru, consider the Outback Limited wagon. Six-cylinder no-turbo engine, 256 horsepower, 5-speed automatic transmission, etc. etc. etc. etc. etc.
T2urtle
3,432
test drive the 6 cylinder legacy/outback. I think you will be happy with it.
