...ok first I am running a brand spanking new 2xDual Opteron 280 system, 4GB RAM. WINXP64.
Currently the vendor has temporarily put a GeForce 6600 card (will be replaced with a GeForce 7800 512Mb card in a week or so when it becomes available in this country).
I uninstalled the latest GeForce 88.xx drivers and installed driver version 77.77 as the Maya (3d software) interface was getting messed up...things are relatively better since installing 77.77 drivers.
BUT I am having a small problem. I am rendering some images for print at 5500 x 5500 pixels. The render goes like a dream and I can easily save the rendered image...BUT then if I move the finished rendered image which is in the Maya "Render window"...zoom in zoom out...etc etc...the PC either a) freezes (no control/alt/delete possible OR b) restarts.
Any idea on what could be causing this? The cooling is rock solid as it never crashes under full load. Could the GeForce drivers be causing this? What is it about moving the huge rendered image in Maya "render view" window that is causing the system to restart /crash?
Btw I can open the saved rendered image in Photoshop without any problem and play as much as I want.
Any advice? Thanks
Any advice? Thanks
