I don't own a 7970, but if OpenCL doesn't work on Vegas Pro 12 with a 7970 then someone should really tell AnandTech...
http://www.anandtech.com/bench/GPU13/588
Its pretty impressive the 7970 ghz is almost twice as fast as a GTX Titan,
in Vega Pro 12, with OpenCL.
Hell even a 7770 beats Nvidia's fastest GPU the Titan in this bench.
I can confirm. I own a 7970 and I render videos with OpenCL, takes only a few minutes.
Anyone render using OpenCL with Sony Vegas Pro 12 and a Radeon 7970?
Everywhere I read says OpenCL/GPU doesnt work in Sony Vegas when using a 7970. Can anyone confirm this or tell me that it in fact works? If it does work for you, what are your render times?
Ok, don't mean to resurrect this forum but this forum is the only place that's even remotely close to what's happening to me.
I have a single Sapphire Radeon 7970 GHz Edition and any time I try to render anything using the same settings as DarkKnightDude it will NOT render to the GPU, it always goes to the CPU and takes forever. I already have the most up to date drivers (even tried old drivers and installing the SDK driver pack), I've even gone so far as to reinstall Windows and try a different PCIe slot with no success! Any setting in Vegas I check is set to use the GPU (OpenCL) and when I go to the system tab in the render settings and click check for OpenCL support it says that it's supported and available.
I'm at my wits end! Please someone tell me that I'm just overlooking a stupid setting somewhere or that I have some kind of strange hardware combo that's problem causing the problem.
Or even point me in the right direction to where I can figure this out.
If it helps I have a Phenom II 1100T processor @ 3.8GHz, 16GB Corsair Vengance DDR3 RAM (4x4GB), Asus Sabertooth 990FX motherboard, Thermaltake 1000W PSU, 120GB SSD (which Vegas Pro 12 build 670 is installed on) and other data drives where the files being rendered are stored.
That helped a bit. Instead of rendering at about 10 frames/sec I'm now rendering at about 15 frames/sec so it definitely helped.
For the most part my settings were the same as this guy's except for the couple at the first of the video.
I was watching the CPU and GPU utilization while it rendered and this time the CPU was at about 50 to 60% where the GPU occasionally spiked to 50 to 60% as well so I think I'm on the right path here lol.
Sorry for posting on an old thread but I was wondering if anyone here had any luck with the Radeon's running Vegas 12? I just got a 7970Ghz Edition and the rendering speeds are awful.
Thanks
Just a short FYI. OpenCL rendering in Vegas is NOT supported with the Main Concept encoder - even tho it claims it is. Vegas will prep the frames using OpenCL and then pass them to the MC encoder which won't use OpenCL.
However, the Sony AVC encoder uses OpenCL and is 2-3X faster than a CPU only encode.
