OpenBSD 3.6 - Need help getting the sound to work
Submit
793
The installation went fine, everything is working except for the sound. I would like to use the built in sound on the Asus P4C800 Deluxe.
Here is my dmesg
auich0 at pci0 dev 31 function 5 "Intel 82801EB/ER AC97" rev 0x02: irq 5, ICH5 AC97
ac97: codec id 0x41445375 (Analog Devices AD1985)
ac97: codec features headphone, 20 bit DAC, No 3D Stereo
audio0 at auich0
auich0: measured ac97 link rate at 47997 Hz, will use 48000 Hz
Any ideas on what I need to do?
Thanks
Submit
793
I tried playing a few different sound files using xmms and nothing happens
n0cmonkey
42,936
Did you add support to XMMS for those file types? If they're mp3s, try mpg321 instead.
These are the XMMS packages I have installed (version numbers may differ because I'm using an old snapshot):
$ pkg_info | grep xmms
xmms-1.2.10 Multimedia player for the X Window System
xmms-esd-1.2.10 Esound output plugin for XMMS
xmms-mikmod-1.2.10 Mikmod input plugin for XMMS
xmms-mp3-1.2.10 MP3 input plugin for XMMS
xmms-vorbis-1.2.10 Ogg Vorbis input plugin for XMMS
Submit
793
Hey drag,
For now, I am logged in as root. These are the packages I installed:
xmms-1.2.10.tgz
xmms-mp3-1.2.10.tgz
xmms-vorbis-1.2.10.tgz
xmms-smpeg-0.3.5.tgz
This is what I get
** ERROR **: /dev/audio: Device busy
aborting...
Abort trap (core dumped)
tango#
n0cmonkey
42,936
If you're using KDE, either add arts support for XMMS or turn off artsd. If ESD is running, either kill it or add support for it to xmms.
Submit
793
I am running KDE 3.2, what are the names of the packes for arts and how can I tell if ESD is running?
tango# pkg_info | grep xmms
xmms-smpeg-0.3.5 MPEG and VCD video playback in XMMS
n0cmonkey
42,936
I believe KDE uses arts. So you can try ps -auxww | grep art to see if it is running.
OpenBSD's sound drivers are pretty "dumb," in that only one thing can bind to /dev/audio at a time. artsd binds to /dev/audio, and I think it should handle allowing multiple processes go through it to get to the audio hardware.
Unfortunately there doesn't seem to be an arts xmms... I'll post again if I can find something. Try killing arts for now. :p
Submit
793
Kiling arts will allow the file to play, so xmms doesn't crash, but still no sound. The volume is turned up:)
n0cmonkey
42,936
It looks like someone started an XMMS-arts port, but it was never finished.
Seriously, kill arts and try mpg321. I don't trust xmms. :p
n0cmonkey
42,936
mpg123-0.59rp2-esd.tgz
0r
mpg123-0.59rp2.tgz
ps -auxww | grep esd should tell you if you are using ESD. I think ESD is like arts, but by a different person/group.
Submit
793
Ok, I will try that.
Does this look right?
auich0: measured ac97 link rate at 48006 Hz, will use 48000 Hz
Shouldn't it be 44kHz?
n0cmonkey
42,936
I don't have a line like that in my dmesg for either ac97 (which is disabled) or my soundblaster...
