http://www.amazon.com/1501372-Strap-...5&sr=8-3-fkmr1
Only the black one, add to cart and it shows up as 13.99. Easily one of the beefiest and most recommended strap around. Great if you are starting out or want a new pad to use with your existing connectors. The Pro Loop Strap is basically a Pro Strap with a loop connector, my personal opinion is that if you like to hang the camera in front, then the length of the loop connector is OK, but if you like to hang it around your shoulder like a messenger bag, then it will be too short. For that you will need to get an additional sling strap transformer, or the old Pro Strap with web connector instead of loop.
