Op amps
tontod
Excuse me for posting this, I am stuck on this, figured folks in here might be able to help or give me clues.
I'm taking an EE class after a number of years, and dont remember this material. It is about an output response of an op amp
"A standard inverting amplifier with gain of -10 is designed where the effects of the op amp input and output impedances may be ignored. The op amp has DC gain a0 = 10^5 and two break frequencies which are f1 = 1.5Hz and f1 = 1500Hz. For a unit step input, find the output response of the amplifier in the time domain. (Hint: Use the Laplace transform starting with the two-pole model of the op amp corresponding to the given data.)"
I just dont remember Laplace at all. If anyone can even give me general ideas/hints to proceed, that would be great also, thanks. Feel free to PM me regarding this problem.
Thanks.
Originally posted by: Special K
Do you have a schematic for the circuit in question, or can you describe all the connections?
Its just a basic standard inverting amp, with the positive terminal grounded and having 2 resistors - a feedback resistor and a resistor connecting the inverting terminal.
I guess I figured if they are giving frequency response data, there must be a capacitor in there somwhere to make it an active filter.
Yeah, you'd think, but I looked again, I dont see any mention of any caps. Thanks for the help. Much appreciated. 🙂
Argh I couldn't finish it, I got to the end but I'm not sure of my answer and I don't want to give you a wrong one. I'll let someone who is more sure of what they are talking about respond.
Thats ok, its more than what I got. I'll look it over, maybe I'll be able to spot a mistake. Feel free to send it over.
OK, here's how I'd go about it.
First, you need the transfer function of your input in the Laplace domain, that's easy enough, it's X(s) = 1/s with a region of convergence (ROC) Re{s} > 0
Next you you need to determine the transfer funcition of the inverting opamp in the Laplace domain.
Well that's easy enough it'll be H(s) = k/[(s - 1.5)(s-1500)]. To solve k, we know that H(0) = -10 = k/(1.5*1500) -> k = -22,500
So you now have H(s) and X(s), you can solve for Y(s) = X(s)H(s). Y(s) = 1/s * - 22,500/(s-1.5)(2-1500). Now do the inverse Laplace transform on Y(s) using partial fractions and you'll get y(t).
OK, this should give you a very close answer since your alpha is large. I don't really want to think about how you'd get a more accurate answer but you'd have to model your amplifier using a feedback loop using alpha_0 to determine your forward gain. Conceptually, it is the same problem but your H(s) would be messier since you're accounting for the non-ideality of a finite open loop op-amp gain.
I hope this helps you, 🙂
I think the two poles they have given you describe the op-amp itself without any components added to it. So, the poles are due to the parasitic capacitances internal to the op-amp.
You need to write down the characteristic of the op-amp alone first. It may help to remember that by replacing s in a Laplace transform with jw, you get the frequency response of the op-amp. Remember to put the poles on the left hand plane. Otherwise, you will have an unstable op-amp!
I have made the assumption that by "break frequency" you mean poles. That would be a downward break on the gain characteristic.
Then, you use control theory and consider 2 resistors one feedback and one from the input to the negative input of the op-amp with a ratio of 10 to give you a gain of 10 (20dB). You started with the open-loop characteristic of the op-amp. So, you will end up with the closed loop characteristic.
Then, you have to work on solving the equation for a unit step, which has a known Laplace transform.
