OOS!! Decent case for a HOT price - $19.99 + shipping
solo
148
Comes with a 300W power supply and shipping for me to Atlanta is $11.76
It says it's a one day special, I don't know how accurate that is, they could just leave that posted all the time.
Linky-poo
kliza23
1,509
Looks like a pretty hot deal to me :)
I may have to pick one up for a second box I have been wanting to put together.....
Thanks!
In Christ
Jesse
Shigoki
I picked up the 400W version for $39.50
very happy with it.
...for some reason, they shipped an additional 400W ps seperately about a week later.
solo
148
How nice of them to give you an extra power supply. It shows they must be very customer oriented. :)
Bill00
265
From the picture on the site I can only see a place to mount a single case fan. Since you already have the case, is there anywhere to mount a second fan, or is there some way to easily mod the case for another one?
If the case can handle a second fan I may have to get one of these too. Combined with the Oupost K7S5a/1GHZ Duron deal (if it goes back to $79 or $89) along with some of the low-cost peripherals I have laying around here could make for a VERY nice cheap system! ;)
Thanks for any info.
Buz2b
4,619
Looks similar to the "generic" case I bought for a second system once. You can probably cut into the back right next to the I/O plate and put in one or two 60mm fans for additional venting. I'm pretty sure an 80mm won't fit there but the 60's do a decent job of venting the hot air. Either that or put an 80mm as a top blowhole.
stockjock
4,205
I have bought a few cases from this place...I have to say that I can't find any reason to complain. They ship very fast and the product is as advertised. The cases are very adequate for my needs.
Boxxcar
364
Does anyone know if the power supply is dual voltage? (110/220VAC) I just check the PCA Inc for details and it doesn't specify. Anyone know?
barabas
Banned
Apr 26, 2002
183
Should be. The power supply (and the case) is LinkWorld so check around.
The case is very cheap but now everything depends on shipping. Not much of a case but with that price it is not fair complaining.
jjmIII
8,399
This place always has cheap cases (cheap, fast shipping too). I've used them lots. I've used this case and feel it's just too cheap. The power supply holes stripped out very easy (2 of the 4), and it needs to be removed to install the mobo. EDIT my comments apply to this case.
A good case just seems to make a pc. Especially one you piece together outta cheaper, used parts. This case they sell is much nicer I think.
Also keep an eye out at Fry's and Best Buy for the Antec KS-282. Great case for $50......tax, but no shipping.
barabas
Banned
Apr 26, 2002
183
This linkworld case has two flaws - front cover is snap on and if you are not careful plastic hinges will break.
Second - floppy is spaced improperly and it is a pain to use it. If you use floppy often (I don't) it is really irritating.
I have one with K6 still working well but had enough of it and wouldn't buy any more. If you are looking for cheap cases look for PowMax cases, these are cheap and well made, plus the power supplies by PowMax are better than Linkworld.
About that Antec/Chenbro/Cheiftech cases - bueautiful but darn heavy. Next time I'd rather go for Skyhawk alluminum.
bambam
652
For you Atlanta folks . I found one with 300 watt AMD PSU at FCS Computers for $ 27.00 + sales tax.
b0mbrman
29,470
I was thinking about getting one of these for my dad but I was really worried about the quality...
tedinde1
365
shippings $6 for me to delaware. This case and their other one get posted in here, every week by someone.
