OOPPSS!!!!......I screwed my mobo straight into my case not into the brackets!!!!
mobutter
24
yeah i plugged everything in and pushed the power button on the back.....as soon as i did that a faint, high pitched sound emanated that quickly stopped....it sorta sounded like a vacuum cleaner right when u push the off button except much fainter. if u think my board is scorched, can i send it back for another?
bacillus
14,517
you could try remounting the board on the correct standoffs & seeing if it works but it doesn't sound hopeful! :(
human2k
3,563
sounds like your board is screwed, try rma'in it tell em it came like that ;).
C0nr4d
13
not good not good, u shorted all the ICs! well at least uve learnt a lesson now :p ull know not to do that in a hurry! try RMA it, butif i was at the other end dealin with ram requests i would decline u :p
CAMS
471
"mobutter"
Out of interest how can you do that?
The board wont line up with the universal plate on the case, it would be to low.
Non of the cards will seat fully into the slots as the board is to low.
Madcowz
2,652
lol, I accidently did the same when I was building my first computer... luckily I caught my mistake before I turned the thing on. In any case, I hope you didn't do any serious damage!
mobutter
24
would i have hurt my athlon, graphics card(radeon8500), anything else by doing this.......also, whats my chance of returning the mobo and sayin that it was DOA.......does that work?
Jabroni
351
Your MB is toast.
I would test your CPU and RAM, but they are probably fine. The board probably shorted before power even got that far, (did you catch the funny smell) but that would depend on where you screwed it into the mount.
My girlfreind just did the same damn thing to the MB I gave to her as a gift. It had a 1.33 and 256MB of ram that are okay still...
My board I sent back to try and RMA it, I don't know if they will or not. I bought a new one, because I assume they wont do anything about it...
WarCon
3,920
I am amazed you got the cards to seat. I am sure they gave you trouble. I personally can't advise to return it since your the one that did it. If you call the RMA department and are truthful, they probably won't help you, but they might.
I can only guess that your mobo is dead, it might of killed your processor and maybe your memory. I doubt it would of killed much else, but you can only tell by putting them in a working system and see.
mobutter
24
is their a way to tell if the board is scorched by hooking up a mulitmeter to it? if so, where? btw, think i'm going to get the msi board.....heard too many bad things about ecs. The manual is not very good.
iamthebear
97
No offense, but the board is not DOA - to return it as such would be stealing. This kind of behaviour makes prices higher for the rest of us. You made a legitmate mistake, they may or may not refund your money. If they don't, expensive lesson learned.
Strych9
1,614
<< No offense, but the board is not DOA - to return it as such would be stealing. This kind of behaviour makes prices higher for the rest of us. You made a legitmate mistake, they may or may not refund your money. If they don't, expensive lesson learned. >>
Like you wouldn't try to RMA it yourself....sheesh :p
GTaudiophile
29,767
33
I don't get it! You forgot to install those little gold-colored risers and instead screwed the mobo into the base of the case itself?
