Only one power fan working ?
trojans
Hi,
Here is my config. : CPU E6400
MB P5W
CASE antec sonata 2
This system is OCed at 3.12GHz
The problem is I just found that the outside power fan (the one sucks air out)
is not working, is this normal ? if not, what should I do ?
Thanks in advance for any help.
cheers,
Pciber
977
Yes, the fan inside the power supply that you can see from the outside does not spin unless the heat sensor detects it needs to.
