- Jun 24, 2001
- 24,195
- 857
- 126
I still don't fully understand how a Fast Ethernet switch can be "full duplex" and a CAT5 crossover cable can't, but does Gigabit have the same restriction (Full duplex only with a switch)? Which should I use, crossover or a switch?
My usage will be fairly intensive. Daily DVD and CD image transfers, weekly hard drive imaging, file access and storage for both the laptop and the media machine on the fileserver.
I do plan on adding a Windows XP Media Center HTPC to the mix someday and Gigabit will come in handy for off-loading all that Media Center content and accessing everything the rest of the computers have access to (It will be exclusively connected to the HDTV). I figure that a switch will be used/required in the future, but I really don't have the money now unless performance will suffer. Only the media machine and the fileserver will use Gigabit. The laptop uses 802.11g, so it's irrelevant.
Also, I was told that Gigabit crossover cables are made much differently than 10/100 crossover cables so unless you KNOW that the answer applies to Gigabit Ethernet also, please don't assume it does and missinform me
