only $174!! HOT!! HOT!! HOT!!
Munny
http://www.monarchcomputer.com...mp;Category_Code=AMD64
is this a good buy or is it too cheap
anyone bought anything from this site b4??
also im lookin for ram which is the best from these
http://www.monarchcomputer.com...ry_Code=Sale_Clearance
Corsair 512MB PC-3200 TWINX-Dual Channel Kits - TWINX512-3200???
http://www.monarchcomputer.com...ode=Unbuffered_Corsair
or these OCZ 2x 256 MB DDR RAM @ PC3200 / 400Mhz Value Dual Channel Kit
http://www.genitechcomputers.c...Channel+Kit/index.html
im looking for cheap ram that overclocks good
thanks
Dood, you should know when to take a hint. This is not the forum to ask questions in ..furthermore its obvious you already knew that so you lied and did it anyways.
You should be put on the blocks for this. :roll:
Monarchcomputers is a great website. They have 9.56 reseller ratings. They work close with AMD also. They get the chips first usually. I'm getting the 3000+ from them for $140 shipped.
