Alright, so when I boot up my computer about 25% of the time it will NOT find my hard drive.
I recently bought a CDRW and the drive will not burn from my hard drive, however it WILL copy a CD from a seperate cd rom. I put a spare HD in and installed windows and nero on it and it buned from my original hard drive with no problems at all from the instance of nero installed on F: (the spare HD). If I take out the spare hard drive, the burner will no longer burn from the original hard drive anymore.
After fooling around with my system trying to figure this all out I decided to try the windows recovery disk and try to repair my master boot record (mbr) when I try to do this, it shows a message warning me that windows has detected that my master boot record is of a different type or is faulty and that if I try to repair it I will possibly lose all data on the partition...
Do does this mean the mbr is the source of both my problems of my system not always detecting my hard drive AND that I can't burn a CD from said hard drive as well? The only other things I can think is that the hard drive is faulty or the mobo is faulty, but as you can see, both under certain circumstances worked just fine.
Any ideas? I'm truly stumped.
I'm not sure if I should just go buy a new hard drive and dump all my data on it, and then try my luck with repairing the current drive or not...
