One Line Not Getting Power
Carbo
5,276
11
I noticed today that one line has no power. First thing I checked was the panel, no circuits tripped. Two GFCI outlets in the house, neither on this line and neither one tripped. Total of 5 outlets not working. Not the sharpest knife in the draw when it comes to electricity. Opinions on what might be going on? Thank you.
herm0016
8,524
1,132
I am an electrician.
one circuit from the panel?
do you know which breaker it corresponds to?
sometimes they trip and they don't look like they tripped.
breakers can also go bad.
Reactions: skyking
Carbo
5,276
11
At first glance it doesn't appear any circuit tripped, but I'll look again. It's an older panel and the breakers are no longer clearly marked. Guess that means going through them one by one. :confused2:
Carbo
5,276
11
Just ran through all the breakers, off and on. None were tripped, all remain on. Time to call a local electrician and get this taken care of.
herm0016
8,524
1,132
if you don't have any electrical experience, I always recommend you call a pro when you get to the point the panel has to be opened.
good decision.
sdifox
101,180
18,211
It is entirely possible there is a GFCI socket in the chain that you don't see. Ran into this in my last house. Someone encased it and we only saw it when we renoed. I lost use of a few sockets because of that.
Reactions: skyking
Paperdoc
2,523
388
OP, you're right to call a pro. Diagnosing this requires some tools, and a good understanding f\of electrical circuits and the logic of testing and diagnosis. PLUS the REAL issue of safety when dealing with live wires, especially inside the breaker box. Without that you are in potential danger doing it yourself, AND you may still fail to identify the source of the problem.
Greenman
22,486
6,572
Residential wiring is pretty elementary stuff, though I have seen a couple bazar failures.
Carbo
5,276
11
Electrician is on his way later today. Hopefully nothing too serious.
With that said, the panel is the original, pushing 40 years. I'm considering upgrading to a new, 150 amp box. Yeah or nay, and what might I expect cost wise, here in south FL?
WilliamM2
3,029
896
I have a panel that will be 50 years old next year. 100 amps. Last inspected 6 years ago when I had AC installed. I thought I would need a new panel, but the inspecter said it was fine. In reality, almost everything in my home is more energy efficient than it was in 1974 when it was built.
Breakers go bad sometimes, but the panel is solid metal. nothing really to fail. Although I know there are issues with certain Federal Pacific, or Zinsco panels.
The cost to replace it was close to 2K 6 years ago. Who knows these days.
Greenman
22,486
6,572
Can't tell you replacement cost, but 40 years old isn't a big deal.
If it's a Federal Pacific panel, have it replaced. The old Federal Pacific breakers don't trip at the correct amperage and start fires.
Reactions: herm0016
14,074
You need to find where it feeds from, it might be another outlet. You have to think in physical logic of where the wiring passes through. For example I would check the connections of nearby plugs that do work, think of what is on the other side of the wall too, as the string of plugs might feed off a plug that is in another room and that plug might work, but the wire coming out to feed the rest is loose. Hope they did not backstab the plugs, those connections are notorious to fail over time and are a pain to deal with without the right tool to release the connection.
herm0016
8,524
1,132
older GE stuff and Zinsco also suck.
other than that, old panels are just fine.
Paperdoc
2,523
388
I agree with several above about replacement. 40 years is not too old for most.
I just replaced our house's main panel and exterior mast feed system but NOT solely for age. It was 51 years old with FUSES (not breakers) that I had installed as a poor graduate student at as low a cost as I could. Last summer we replaced our central gas furnace and added AC, but even the AC compressor unit needed only about 10 A max at 220 V, not a big added load. But our other main project was adding a new garage out at the back with a cable buried to it for electric power. As I have that wired the projected max load on a standard 120 / 240 V split feed would be about 20 A, again not too huge, but an increase for sure. However, in anticipation that someone in the near future might want to add to that garage a charger for Electric Vehicles, that item can easily be a 30 to 40 A load in today's designs, and might be over 60 A in future designs. So the buried cable and sub-panel are rated for 100 A. To accomodate all of that I DID have a contractor update our old 100 A service panel to 200 A. As I said, though, that was for projected major load increase, and not for age of the equipment.
Different size of service, and I don't live in the USA, so my costs probably do not help.
Carbo
5,276
11
Update: electrician came over, found a bad outlet and took care of the problem. Power back to all 5 outlets. $120
While here we talked about the existing panel. Turns out it's a 40 year old Federal Pacific. He suggested I replace it ASAP. It's a 150A box. Took at look at the outside box. Federal Pacific 200A. He offered to replace both with Siemens boxes, quoted $2400 for both.
WilliamM2
3,029
896
Not much more than I was quoted 6 years ago for a SquareD. Probably fair, if it's a 200A panel. Make sure there will be extra spaces for breakers in the future. I've ran out on my old 100A, had to use a tandem breaker for one of my circuits.
Your description in confusing, you say it's 150A box, but it says 200A on the outside? And what do you mean he will replace both? Thought it was one panel?
sdifox
101,180
18,211
eh? that means the original installation was not up to code. You are supposed to pigtail each outlet to prevent the problem of one bad outlet taking out the chain.
Carbo
5,276
11
There are two panels. The exterior panel on the side of the house is 200A. The panel inside the garage is 150A. Electrician suggested replacing both since they are old Federal Pacific units and apparently they are fire risks.
Greenman
22,486
6,572
Yup. Federal Pacific breakers don't "break", they start fires.
pcgeek11
22,418
5,019
In older houses I see Daisy Chained outlets all the time.
Top is Daisy Chained (series) ** not really series but it is often called that.
Bottom is Pigtailed (parallel)
main-qimg-aab38032928d5f5ac3796050a5c10f2c
