once Kazaa is on = slow transfer speed online
faye
Hi, once i turn on Kazaa, my download speed drop dramatically.
when i check the bandwidth from Kazaa, it is just only 3.0kb/s or 5.0kb/s
i use cable, so it should be able to do over 100.0kb/s
Internet Explorer just stop. , like there are 10 IE running.
i want to see if i turn on something that is taking all the bandwidth.
and how can i check the total bandwidth that is transferring?
thanks
That's just all the people grabbing files from your harrd drive, \my documents, \my pr0n, etc.
And the adware / spyware / spamware / trojans.
i don't have any popup.
upload is still below 15.0kb/s
downloading from fileplanet and download.com at the same time still give me plenty of room to browse the internet.
Originally posted by: DarknRahl
Yes, and you will find most cable providers cap your upload speed at around 16kb/sec...
And due to the way cable works, if you are uploading at your full speed, your download speeds will drop down to the same level, or even lower, than the speed with which you are uploading
Confused
Plus the fact, that you can only upload and download as fast as the persons that you are uploading/downloading to.
Confused, was does;
"Encryptic on Avril Lavigne" mean?, in your sig.
Confused, was does;
I think its a quote about Avril Lavigne made by someone called Encryptic 😉
Confused, was does;
Yup, Encryptic's life is now complete as he has been sigged for something he said 😛
Confused
