Onboard sound worse than PCI sound for the same chipset?
Woodchuck2000
1,632
Just a quick musing: A number of chipsets which are commonly found onboard (such as the C-Media six-channel and the old SB PCI128) are also available on cheap PCI cards. Are there any benefits of having the PCI version? Will the CPU usage be the same for a given chipset regardless of connection method?
I can't find any benches, but if someone could point me in the right direction...
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
They should be exactly the same. The only advantage to the "onboard" sound processors is that they save 1 PCI slot.
