Onboard sound vs. PCI card
MX2
18,651
Currently running 5.1 digital out on my NF7-S. If I buy a PCI 5.1 card, will I see some big improvement related to CPU/memory usage taking the load off of the onboard sound and my mobo???
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Keep in mind that not all cards are going to do 5.1 digitally and the ones that do aren't going to have as low CPU usage as say an A2 or something.
What are you hooking up to?
Are you still planning on using a digital connection?
MX2
18,651
Yamaha TSS-1's. Yes, keeping it digital through FO is a must.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
If you still need surround sound in games, then check out cards with Dolby Digital Live.
HDA X-Mystique, Turtlebeach Montego, etc.
On the HDA at least it seems like DDL doesn't really give much of a performance hit vs 6channel. http://www.nvnews.net/reviews/x-mystique/page_3.shtml
Have you thought about hooking up via 6-channel direct if you have that option?
Slick5150
8,760
You're using soundstorm via digital, which is really quite good already (about as good as onboard sound can get).
