I just realize that the ALC650 AC97 audio codec on the Abit IT7 MB only works when the PCI bus frequency is set to 33MHz. When the frequency is set to 37MHz or higher, the audio codec stops working. I am wondering if this is normal? I check the ALC650 spec. There is no mention about the PCI bus frequency. If I am using a PCI sound card, I will understand why it only works at 33MHz. But does the onboard audio codec have anything to do with the PCI bus frequency? Is the onbard audio codec considered a PCI device?
BTW, I couldn't find the spec for PCI on the Abit IT7 MB. If it supports PCI 2.1, shouldn't it support up to 66MHz?
Thanks.
Steve
Thanks.
Steve
