My board specs are at
http://www.pcchips.com.tw/M754LMR.html
Intel P3 733
192Mb ram
Onboard TNT2 / PCI Voodoo3
My problem is, i have a PCI Voodoo3 that i want to run instead of my Onboard Alladin TnT2.
When i set my primary graphic adaptar to PCI in the bios everything seems to work fine but the system freezes while windows loads.(*i was succesfully booting in windows a week ago, but strangely enough my internet wouldnt work for some reason after 10min)
Do i need to deactivate the onboard Tnt2 in windows? or manually?
The board manual doesnt even explain how to deactivate it.. all it says is that "the default PCI setting still lets the onboard display work and allows the use of a second display card installed in a PCI slot."
Any help is apreciated, and if more info is needed i'll be glad to give them.
Thanks a lot.
FTemplar
Intel P3 733
192Mb ram
Thanks a lot.
FTemplar
