Onboard LAN vs PCI LAN
meatbomb
37
Hi
I was wondering if an onboard LAN, such as the onboard 10/100 on the ECS K7S5A, could render my 3Com 3C905B-TX obsolete. Which would have the lowest CPU usage and best performance?
If my 3Com is still better, should I disable the onboard LAN and use my PCI card?
Thanks
jsbush
3,871
I would just use the onboard lan. You just won't see a difference between the two IMO. Of course your 3com is better, but it will just use up a pci slot, and you could sell it make some money or what ever.
reicherb
2,122
You'll get better performance and less complications from the PCI NIC.
Integrated NICs suck!
Nothinman
30,672
99% of the time it's all in the drivers, as long as the onboard card's drivers are decent it's worth using.
Most of the integrated NICs I see are just common cards soldered into the main board, like Intel and 3Com cards.
sml
193
Since most of the applications I work with are fairly network intensive, I get nervous when I hook up a machine with a 'generic' or Taiwanese integrated network card or whatever. Most motherboards I get ahold of with an integrated NIC are 3Com/Intel network cards soldered onto the board. Most people will tell you it doesn't really matter when you benchmark it out, but it never hurts to have a name brand :)
mboy
3,309
You wont notice a difference at all with the PCI vs integrated. I have a K7S5A and use the integrated as well as the 3com in my 8KHA+ and notice no difference thru my Linksys router + cable modem to the net.
osage
5,686
the onboard nics on my 2 k7s5a have retired 2 of my Intel Pro 100+ pci nics, I still use an Intel on my other non onboard mobo
