I don't think that is the case to be honest. Maybe someone else can clairfy, but Im pretty certain that even on-chip (ie on the die of the south bridge) devices typically are just connected to the PCI bus like a card would, and certainly external solutions (ie all the realtek on-board LAN's, all the CMedia Audio, all the NEC USB2 Chip boards, etc) are connected to the PCI bus. Sure there are some onboard stuff that aren't on the PCI bus but most are still just devices on the PCI bus.Originally posted by: gaidin123
One advantage to onboard peripherals like NICs, sound, etc. is that they only use some bandwidth between the north and south bridge chips and do not take up any of the 133MB/sec of the PCI bus. So if you really needed to saturate the slow PCI bus it would be to your advantage to use integrated features of many modern motherboards.
