Onboard LAN problems
Toolex
13
So, i've got a problem with an onboard network controler. basically, after the driver is installed and the network cable is plugged in it says "network cable is unplugged"...i've tried reinstalling and updating the driver to no avail. any ideas?
Toolex
13
its actually a compaq presario that i was fixing for a friend. not sure on the mobo, i think she bought it in 2003?
Toolex
13
BTW: i went to the compaq site and download drivers using the computers product key, so this "network driver" should work. However, what strikes as odd is the fact that the driver name says "NIC", however this is onboard.....One more thing, XP recognizes the network controller and installs the same driver automatically.
Cares
868
Maybe it is unplugged on your router's end? Or maybe your router is broken.
Toolex
13
No, i am on the current network cable right now......all i do is unplugged the cable and take it to the other computer...i've reset the modem as well
allanon1965
3,427
NIC is a general term used for Network Interface Card, and they use it for the onboard versions as well, sounds like the onboard NIC is dead, try installing a PCI NIC and see if it works....
Toolex
13
I've used both a wireless PCI card and a usb-NIC adapter, both worked perfectly. I was not aware that some onboard drivers were labeled as NIC drivers, though. don't really feel like buying a PCI card for the person....plus she says that the port worked fine before. Can't think of anything else? and once again, i am positive that the network side is working fine. thanks!
allanon1965
3,427
you mean you have used a wireless and usb based in this machine and they worked? well you just answered your own question! the onboard has gone bad. its not that hard to figure out:) tell her to spend a few bucks, (15-20) and put in a pci nic.....
