Hi,
I bought two Gigabyte 7VRXP motherboards and have tried everything I could to start them up,but I can't get them to POST. No beeping at all. Screen doesn't come out of sleep mode. Only the fans spin up, along with the HDD. The CD-ROM's LEDs liight up and I can open the trays. The floppy drives' light stays lit continuously. I'm hoping it's something really stupid that I am overlooking.
I have installed only the video cards, memory, HDD, and CD-Roms (along with CPUs and HSFs).
Actually, I once got one to boot and could go into CMOS BIOS setup, but since it was not my primary system, I wanted to put my primary components in, so I swapped in my CPU, HDD, CDROM, and video card. Then I couldn't get it to POST. Stupid me!!!
one has a 2000+, the other has a 2100+.
One has a leadtek Geforce4 4600, the other has a PNY Geforce4 4400.
Both have 431 watt power supplies.
Both have 512MB Corsair DDR3000 CAS 2 memory.
One has a Pioneer DVD-burner, the other a Yamaha CD-RW
Both have a Silverado HSF
Both have a Teac floppy drive
Both have WD Caviar drives (not like this makes a difference if I can't even POST?!?)
Have been switching machines to and from MS Office keyboard (USB) and intellimouse explorer (also USB).
And of course, both have more hardware, but not installed yet.
FSB set at 133. Computer turns on, fans run, no beep, Power light turns o
n, HDD light sometimes turns on. Can feel HDD in one system spin up. Floppy drive light stays lit. Again, cannot get into BIOS setup, Monitor does not enter from sleep mode. Tried booting from FSB 100 and still didn't work.
The setup that worked once (before stupid me swapped out the parts) was the 2000+, Yamaha CD-RW, PNY Geforce4.
Does it make a difference whether the machine will POST or not if the HDD or CD-RW drives are installed? Technically, I shouldn't need to connect the HDD or CD-ROM to get them to post, should I?
I really want to try Morrowind with my new Leadtek card! can you understand how frustrating this can be!?!
I feel dumb asking this question, but is DDR3000 cas 2 memory too fast for this board? I am going to try some PC2700 memory.
Any suggestions to get these machines to POST? seems more like user error than faulty MBs?/ what are the chances that I am sent two faulty motherboards?
