I'm using Windows XP Pro SP3. When I turn on the computer, the "On AC Power" icon is in the taskbar. I go to Control Panel > Power Options > Advanced > and uncheck "Always show icon in the taskbar". The icon disappears. Then, after restarting, the icon is back, and the box is checked again!
I used to use on APC UPS, but not anymore. Could there be some setting that needs to be modified?
Also, I recently changed the settings for what to do when the power button is pressed (also in Advanced Power Options). I changed them to "do nothing" because my son kept pressing them. I can't remember when this problem started, but I believe it was soon after changing those settings.
