That depends on what kind of input polling the game uses. I doubt you'll notice any real difference in actual input response but the smoother overall feel of the game is perceivable.
Correct it's engine dependent but smoother overall gameplay I'm sure we could all agree is what we should be aiming for.
I don't agree about the coating on the ROG Swift (it's fine IMO) or blur reduction darkening the image. Darkening only happens if you set the pulse width very low but at 90% on my ROG Swift there is no real difference in ULMB mode to normal in brightness. I have my regular brightness setting around 20 which is just fine for using even in daylight. I find ULMB is best for very fast paced games that can also run at 60+ fps so mostly first person shooters.
And here-in lies the problem with ULMB. In order to get the smoothest looking playback you need to set the pulse width to 20 or lower which kills the brightness and is counter productive. This isn't too bad if you play in a very good light controlled room but if you're playing in a room with regular ambient light this can become an issue. True the coating isn't terrible compared to other panels but it is worse than many of the newer (and cheaper) IPS 144hz panels.
Just by virtue of having a high refresh rate display you get less motion blur overall even if you use G-Sync instead of ULMB
This is why I think just enabling 144hz with proper brightness and contrast is superior to lightboost. If your monitor can handle sub 7MS transitions it makes more sense to get better refresh rates, lower input lag (if a game uses polling, which most do) and picture quality. This is something every gamer will need to test out and judge for themselves. I'm not saying ULMB is useless, I just think there are too many compromises for my liking to recommend it.
The ROG Swift is still afaik the absolute fastest panel. It's main drawback is less than stellar vertical viewing angles which are not at all problematic in normal use (sitting in front of the display). I don't notice an annoying color shift when moving around when sitting in front like you had on older TN panels. Colors are also excellent with very good factory calibration. I lucked out and got a near perfect sample but there have been others who have had terrible luck with these. But the same seems to be true for the Acer models as well, just different issues.
This is the biggest issue with the Swift. You may not think the viewing angles are that bad but they're pretty terrible in comparison to the new Asus or Acer 144hz IPS panels. This isn't so bad while playing back bright fast paced games but becomes a huge distraction for games that are slower paced and have a lot of dark scenes. I had to quit playing Alan Wake on a "decent" TN panel a while back because it was so distracting in dark scenes when then the top 1/4 of the screen shifted to a different colour. This loss of detail shouldn't be underestimated. General colour work on the desktop also suffers so if you want an All in One monitor solution the Swift is a poor choice.
Here's the Swift's viewing angles.
http://www.tftcentral.co.uk/images/asus_rog_swift_pg278q/viewing_angles.jpg
The Swift doesn't escape this TN viewing angle issue.
Quoted from the TFT Central review on this topic.
"As you move your head from side to side in a horizontal plane, there is a contrast shift and the image becomes darker and introduces a slight green hue. As you move to a wider angle the image can become more washed out as well. Vertically the fields of view are more restrictive still. From above the image becomes pale and washed out, while from below there is a characteristic TN Film darkening of the image. Unfortunately vertically the viewing angles will introduce noticeable shifts in the contrast and colour tone of the image which mean that for any colour critical work it is not really very well suited."
Also this Rog Swift monitor has unnecessary and expensive features like "portrait" mode. Seriously? A TN in portrait mode is like looking at a tall beautiful woman but you can't really make out her face or if sitting higher up from the knees down (although this is a bad analogy as some may prefer that
Anyways, I don't mean to slam the Rog Swift, it's still an excellent monitor (the absolute best LCD for fast paced gaming) but with the newer IPS 144Hz options available at the same price or much less money I would hesitate recommending it to anyone but the most hardcore of competitive gamers.
