OM: 5 GB USB drive for $99
oslama
3,103
33
Its the Microadvantage 5 GB USB drive. It has a 5 GB CF card in it.
Its on Clearecne so YMMV.
Spike
6,770
Does this mean you could pull out the cf card and use it in a camera, PDA, etc...? That would be kinda nice, especially for those mp3 players that have CF expansion
-spike
bmacd
10,869
-spike
No special tools needed. The rubber casing splits in half with a knife and the drive pulls right out from the pins.
It's a Sygate 5gb ST1 drive.
-=bmacd=-
edit: however, i'm having a hard time getting it to show up in windows. It physically won't fit in the digi cam I tried it in.
nero2
549
-spike
-=bmacd=-
That's probably because the microdrive is a Type II. Your particular digicam most likely fits only type I cards.
bmacd
10,869
-spike
-=bmacd=-
I still can't get windows to recognize this drive :( I have two card readers that both support type 1 and 2 CF. Neither pick up this drive.
-=bmacd=-
AnyMal
15,780
-spike
-=bmacd=-
-=bmacd=-
Was it getting recognised while still inside the USB drive?
oslama
3,103
33
-spike
-=bmacd=-
-=bmacd=-
did you format it when it was a "usb drive"
bmacd
10,869
Yes, it comes up as 4.94gb and I forget the partition, maybe fat32.
-=bmacd=-
mindless1
8,794
1,776
You might need a card reader using a controller chip that supports 5GB?
What controller chip is in THIS flash drive?
Spike
6,770
I believe there is a way to format the card in NTFS or something similar when it is in the original packaging to get it to be readable in a card reader. I am not sure about this particular one but this was what needed to be done with a generic 4gb drive that frys had a little while back.
Can the chip in the reader really make a difference? I realize it can if it can only do Type 1 but if it can handle both why would the chip matter?
-spike
AnyMal
15,780
-spike
I don't think that digital camera can read NTFS.
bmacd
10,869
The only thing printed on the chip is
"matsunichi ud2136v3.0"
-=bmacd=-
Garlic
Banned
Dec 28, 2004
447
Plug the USB connector of the card reader into one if the USB ports of your PC. LOL!
j/k
aka1nas
4,335
None, The mem controller is built into the card for CF devices. The USB drive is basically an ATA--> USB converter in this case as CF is pin compatable with IDE given the proper physical adapter.
bmacd
10,869
Well, since I can't get this to read in my card reader (despite it working fine in my dad's), i'm going to return this to Office Max unless somebody else wants to send me a MO for this.
-=bmacd=-
bmacd
10,869
Originally posted by: kamranziadar
From where you can buy this? Link just show the USB Drive does not say buy it or the price.
it's posted in the original thread. It's $99 on clearance at OfficeMax, and since it's clearance, your mileage may vary.
-=bmacd=-
